On Semi AMIS-49587电力线载波调制解调方案
2010/3/15 11:41:00
On Semi 公司的AMIS-49587是电力线载波(PLC)调制解调器,把模拟调制解调器前端和数字后处理功能集成在单芯片上.它基于ARM7TDMI处理器内核,包含物理接口收发器(PHY)和媒体访问控制器(MAC)层. AMIS-49587采用扩频型移频键控(S-FSK)调制技术,结合精确的滤波,提供长距离电力线的强固低数据率通信,及2,400 bps(波特)的半双工可调节通信速率. AMIS-49587符合IEC1334标准,主要应用于智能电力自动读表及管理、街道照明控制、智能电力插头和建筑物自动化等等。本文介绍了AMIS-49587主要特性,方框图, 发送器方框图, 接收器模拟通路, 50/60Hz抑制滤波器外接元件连接图和典型应用案例框图.
ON Semiconductor’s AMIS−49587 is an IEC1334 compliant power line carrier modem using spread−FSK (S−FSK) modulation for robust low data rate communication over power lines. AMIS−49587 is built around an ARM 7TDMI processor core, and includes the MAC layer.
With this robust modulation technique, signals on the power lines can pass long distances. The half−duplex operation is automatically synchronized to the mains, and can be up to 2400 bits/sec. The product configuration is done via its serial interface, which allows the user to concentrate on the development of the application.
The AMIS−49587 is implemented in ON Semiconductor mixed signal technology, combining both analog circuitry and digital functionality on the same IC.
AMIS-49587主要特性:
Power Line Carrier Modem for 50 and 60 Hz Mains
Fully Compliant to IEC1334−5−1 IEC 1334−4−32 / EN50065
Complete Handling of Protocol Layers Physical to MAC
Programmable Carrier Frequencies from 9 to 95 kHz in 10 Hz Steps
Half Duplex
Data Rate Selectable: 300–600–1200–2400 baud (50 Hz)
Synchronization on Mains
Repetition Algorithm Boost the Robustness of Communication
Other Features Under Development / Validation
SCI Port to Application Microcontroller
SCI Baudrate Selectable: 4.8–9.6–19.2–34.4 kb
Power Supply 3.3 V
Ambient Temperature Range:−40℃to +80℃
These Devices are Pb−Free and are RoHS Compliant*
AMIS-49587典型应用:
AMR: Automated Remote Meter Reading (Télérelevé)
Remote Security Control
Streetlight Control
Transmission of Alerts (Fire, Gas Leak, Water Leak)
图1.S−FSK 调制解调器AMIS−49587方框图
图2.AMIS-49587发送器方框图
图3.AMIS-49587接收器模拟通路
图4.接收器ADC数字通路和正交解调器方框图
图5.50/60Hz抑制滤波器外接元件连接图
图6.AMIS-49587应用案例框图
AMIS-49587主要特性:
Half Duplex
Power Supply 3.3 V
AMIS-49587典型应用:
Streetlight Control
图2.AMIS-49587发送器方框图
图6.AMIS-49587应用案例框图
新大陆自动识别精彩亮相2024华南国际工业博览会
派拓网络被Forrester评为XDR领域领导者
智能工控,存储强基 | 海康威视带来精彩主题演讲
